Hello
Is there a way to make mikrotik make a sound/music when wifi device connet and disconnect?
for example i connect phone by wifi to mikrotik and he play beep song
i disconnect and play sad song (mario die)
its will be awesome ![]()
There are not a quick way to do it. You have too look at log and if it see a line some like this, then send a beep.
wireless,info MikroTik: EA:XX:XX:92:EB:0E@wlan: connected, signal strength -80
This need to be scheduled, so it will not be real time.
I will have look at it to see if there are other options. Maybe use a while loop (this may use some cpu)
im tootaly noob in this
its will look somethink like that??
Check if log message how this (in this situation ethernet port 5 disconnect)
:local scheduleName "scheduleName"
:local startBuf [:toarray [/log find message~"ether5link up"]]
:local removeThese
Do this - play song
:if ([:len [/system scheduler find name="$scheduleName"]] = 0) do={
/:beep frequency=660 length=100ms;
:delay 150ms;
:delay 300ms;
This should let you go
:global run
:local loginfo
:local prevlog
:while ($run=1) do={
:set loginfo [/log find time>([/system clock get time] - 2s) topics~"wireless" message~": connected"]
if ($loginfo!=$prevlog and [:len $prevlog]=0) do={
:beep frequency=10000 length=1s
:set prevlog $loginfo
:delay 1
Save the code to a script.
Set run to 1 like this
:global run "1"
Run the script
To stop the script, set run=0
:global run "0"
There are several problems with this script.
- If there are many changes within 1 second, it will beep only once
- It uses CPU.
- Does not restarts itself when reboot
- Not all routers have speaker.
There may be better way to do it.
acording to your script
(becaouse im in job right now (have only eth with beeper)- dont have here mikrotik with wifi and beeper
in home i got audience = got speaker
:global run
:local loginfo
:local prevlog
:set loginfo [/log find time>([/system clock get time] - 2s) topics~“interface, info” message~“: down”]
:beep frequency=600 length=1s
:delay 1
is that should work for “unplug” the eth5?
in log its Topics : interface, info message : ether5 link down
if yes
that dont work ![]()
Paste the script to scheduler or scripts?
Do you need a script for connecting ethernet ports or wifi connecting devices?
for Wifi
but i was think it will work also for ethernet
Will be also cool if some device disconnect ( ethernet)
will beep (ether1 ) 1 ( ether2 down ) beep twice /or difrent music
but most important is Wifi connect sound / dissconnect sound
It will work for all.
Just look in the log how it looks like while connecing/disconnecing wifi/ethernet. Change script to look for data in that line.
dont work for now.
System-> Scripting + then
https://prnt.sc/10yzk2o
Its look like this
then i press Run Script
then in terminal
:global run “1” (enter)
i unplug cable eth4
in log show ether4 link down
but no sound
You have modified the script look for eth down?
Script I made only search for Wifi connected. (1 of 4 option in connecting/disconnecting wifi/eth)
Updated version that should not miss any message, since it test number of message and then compare 1 and 1.
But not 100% sure what happens when log reaches 999 entry.
You can add as many test as you like, since it reads all log entry 1 by one.
:global run
:local LogInfo
:local LogLength
:local LogTopic
:local LogMessage
:local PrevLogLength 99999
:set LogInfo [:toarray [:log find ]]
:set LogLength ([:len $LogInfo]-1)
if ($PrevLogLength<$LogLength) do={
:for Loop from ($PrevLogLength+1) to $LogLength do={
:set LogTopic [:log get [:pick $LogInfo $Loop] topics]
:set LogMessage [:log get [:pick $LogInfo $Loop] message]
# Test section
# Test if Wifi going up
:if ($LogTopic~"wireless" and $LogMessage~": connected") do={
:put "wifi connected"
# Test if Wifi going down
:if ($LogTopic~"wireless" and $LogMessage~": disconnected") do={
:put "wifi disconnected"
# Test if eth going up
:if ($LogTopic~"interface" and $LogMessage~"up") do={
:put "ethernet up"
# Test if eth going down
:if ($LogTopic~"interface" and $LogMessage~"down") do={
:put "ethernet down"
# End Test section
:set PrevLogLength $LogLength
:delay 1s
its seems to not working i think
CPU 0%
no beep sound ( in code i also not recognise any beep sound )
the script counter dont “count” also
but i COUNT on you to make it done to work flewless ![]()
Script is just a proof of concept. It does print message to terminal, no beep. (do not have beep on my router)
You need to change the lines :put “wifi connected” to some with beeps within them.
You also need to set
:global run 1
To make it run.
Add { } around the whole script and copy past terminal and it should run fine from there.
FYI At DHCP SERVER there is an option to run a script when a new device gets an IP. this will work for connection but not for disconnection of device
{:global run
:local LogInfo
:local LogLength
:local LogTopic
:local LogMessage
# Test section
:put "ethernet up"
:beep frequency=770 length=100ms;
:delay 550ms;
:beep frequency=380 length=100ms;
:delay 575ms;
:delay 150ms;
# End Test section
:delay 1s
Work GREAT for Ethernet ON and OFF ![]()
Need arround 5 sec wait until “next” thing happen but i guess nobody will connect in same second
:delay 150ms;
can i edit this somethink like ethernet 2 down" or ethernet 3 down difrent command line
so difrent “beep” ?
Also CPU is great usage 0-1%
freemannnn
But its work for new device i guess?
I need for every device difrent sound
{:global run
:local LogInfo
:local LogLength
:local LogTopic
:local LogMessage
# Test section
:delay 150ms;
:beep frequency=960 length=100ms;
:delay 300ms;
:delay 150ms;
:delay 300ms;
:put "ethernet up"
:beep frequency=260 length=100ms;
:delay 150ms;
:delay 300ms;
:delay 150ms;
:delay 300ms;
# End Test section
:delay 1ms
After some tweaks i fnish with that with basic sound of connect and disconnect
also change the :delay 1s to 1ms = react faster almost instant
And work great
Now i will try add mario dead sound for wifi disconnect
some sound of finish bos in game boy when wifi connect
Then some adds like for eth1 eth2 etc difrent sounds for each one
… Work in progress
Warning!!!
Try paste this command line:
:delay 1ms
You will get a warning like this:
Warning: value of delay-time was rounded down to 0s
And this is not a good thing. Look at CPU load. My router goes from 0-1% to 25% CPU usage.
16 devices connected - so its have some “load”
and 0% .. rare 2% usage with RB3011UiAS (arm) mikrotik
DO not press Run Script
Just apply
After press Run script its go 25%
just in terminal :global run “1” and work also without 25% cpu
