Hello
I am George, I have a tp-link router with ip 192.168.1.1
I have 2 mikrotik SXT 5ghz and I want to setup the one to Station and the other one to Access point, I am trying 5 days now but nothing ![]()
Any help! ![]()
Hello
Any help! ![]()
What is the problem you’re having?
This link will help you in basic configuration
http://wiki.mikrotik.com/wiki/Manual:Wireless_AP_Client
I try that one but after 10sec the internet wont work
Try this setup published on my website.
http://www.wirelessinfo.be/index.php/linktesten/pages/linktest-1km-sxte.php
Reset the sxt’s without default configuration.
Copy the code and paste this in the window “new terminal” in winbox.
Change country settings and distance. This example is a point to point configuration.
If you want two sxt clients connect with the accesspoint take the code 2 for client.
Edit the SSID to the ssid from your accespoint
Goodluck
