Beginner - SRC NAT vs Masquerade
The default configuration on my routerboard is as follows:
chain = srcnat
out-interface = ether1-gateway
action = masquerade
Should I change this to action = src-nat?
And in the To-Addresses, should I put in 10.0.0.123 (<- My static IP from my ISP) ?
I remember reading somewhere that src-nat is faster if you have Static IP.
Masquerade will use out-address automatically, src-nat will use only one specific address.
There are no any visible performance issue, when masquerade is compared to src-nat.
For 99% of installations, action=masquerade will perform with great results.
Thank you.
I will take this into consideration!
