beseech ace Give me a Hotspot Template
you can use the default RouterOS hotspot files to create your own. Start with simple changes, like different font color or background image. You will need some basic HTML knowledge, and I recommend using a plaintext editor (Notepad++, Sublime or similar) to not damage the hotspot variables.
