We need to setup some hotspots around the buildings to serve users housed in rooms.
Any idea which is the best 2.4Ghz radio module?
The NMP-8602+ seems to give enuf power to penetrate the walls but there are few horror stories flying around, though our experience with them has been fine.
Our other choices ofcourse are SR2, CM9, R52. My concern is on the power required to penetrate the wall. I will be adding an external antenna (5dBi or so). SR2 has the power but seems a bit more expensive…
Boy DO NOT GO FOR SENAO you will be banging your head into the wall after … search the forum with the term “np8602 problem” and you will understand what am I talking about !
If any how you are interested I can send you one I had on one of my APs …
simply said this is the worst card ever made - senao NP 8602!!!
