best bonding setting
Hi all,
what is the best bonding setting for this
i ve 2 wireless links one with 200Mbps rate (RB921 NetMetal) the second with 500Mbps (AirFiber11FX) i need to know which mode to choose and which layers, also i ve a problem when i do bonding for there devices i cant reach one of them i even cant ping them
Hello Sinan, i have tried a similar scenario with lower links, 100 Mb and 150 Mb and i was able to configure everything so i could reach all the antenas that participate in bonding using vlans; although i was having a lot of issues. This is the scenario i used:
I will suggest that you try with two links of the same speed in order to avoid tcp retransmision. Let me know how it goes.
