Hello, I like to set up a vpn gate for ovpn(It must by ovpn no WG or something else). What is best hardware for this? I have 10’ rack. It must be not expensive. I chose rb750gr3 its good option?
You missed and mention how many vpn connections you will be running at the same time.
And what speed are we talking about ? Do you need sfp or sfp+ ports.
And there are Mikrotiks Distributors that can provide these figures for you.
https://mikrotik.com/buy
For max 20 clients and I dont need sfp of sfp+
Possibly worth looking at and comments surrounding
http://forum.mikrotik.com/t/upgrade-from-rb750gr3/174496/11
I like the hap ac2, though with current routeros versions you will likely need to disable and remove wifi packages.
