Best Config to connect to WiFi AP as a bridge
What is the proper way to config a MikroTik for connecting to a standard AP that most likely does not have WDS.
I know when setting up for a MikroTik AP, we use station WDS, but I am not sure what to use without WDS.
Note ether1 and wlan1 are bridged and no routing is done on the RB, it is simply a transparent bridge.
you can try station-pseudobridge feature.
Is it possible to use STATION WDS on the RB with a CISCO Aironet 1200/1300? If so, how do I enable WDS correctly on the CISCO?
