Best configuration for CPE
I need to know the best configuration for the following:
RB912 sectors and SXT Lite 5 CPEs
Each customer’s max speed is 4Mbps
I can see that sometimes if I have bad CCQ I lower the data rates of the CPE to only a basic rate of 6Mbps and this improves it.
But, does this affect the performance in this case? and would I also change the rate of the RB912 ? or just leave all the rates ?
There are also some CPEs that have other settings in the HT tab which are MCS.
What do they stand for and what should I keep/remove?
Anyone can help me?
I wouldn’t say there is a best config.
It all depends on your situation and needs.
How many customers are you planning to connect to each sector? what will the distance be from cpe to ap?
I have now 50 customers and planning to get 50 more, the maximum distance is 2.5 Km
