Best connection mark practise?
In manlge we have several options to filter traffic.
Example:
;;; http (browsing) conn. mrk
chain=prerouting action=mark-connection new-connection-mark=normal-traffic passthrough=yes protocol=tcp dst-port=80
;;; All normal` marked con. traffic get packet mark “MED”
chain=prerouting action=mark-packet new-packet-mark=MED passthrough=no connection-mark=normal-traffic
As we see I only use one connection marker.
But I see some examples and in router exists “connection state” as well. How, and when to use these?
Should I mark a connection first with “Connection state=new” and then have a second filter just looking to existing connections with “Connection state=established”?
Any advices on this with explanation why please?
[my QoS works fine at this moment I believe but to avoid future problems due growth of traffic flow I want to optimize my QoS as much as possible]
if you use connection-state=new it means that connection mark is assigned only once at the time when first packet arrives. If you don’t have connection-state=new then connection mark is rewritten every time when packet arrives belonging to particular connection.
Obviously first method uses less resources.
OK,
So my example should then read:
chain=prerouting action=mark-connection new-connection-mark=normal-traffic passthrough=yes connection-state=new protocol=tcp dst-port=80
As long as this connection exists in conn tracker all packages belonging to this connection get the mark “MED”
For what purpose is now the “established” option of conn. state? I mean, as long as the connection is there it already gets marked? Is there any need for this “established” option?
Usually not in marking/mangling packets. It’s useful in other situations, such as statefully permitting packets through firewall filters.
Ok fewi, many thanks. You are worth your karma.
Have you seen my other topic: http://forum.mikrotik.com/t/best-mangle-practise/42807/1 ?
I got no replies to it. Is my question too complicated or too stupid to get any replies?
I am trying to discover all finesses of mangle and QoS but I need some confirmation or other opinions at times to se if my thinking is in the right direction. Please comment.
