I have issues with micro-bursts and need something (transparent bridge, passing a few tagged VLANs) to put between 10G and 1G Eth interfaces with largest possible buffer size. This is at the end of a long distance link from a far away (RTT ~17ms) Internet Exchange, mostly 10G fiber except the last 3 miles (1G ethernet, 800M licensed microwave). There is a lot of real, bursty traffic from the Internet which results in some packet loss - about 0.1% at ~300Mbps may seem small, but already degrades TCP speed. The large buffer is needed to smooth out micro-bursts, hopefully reducing the packet loss to almost zero until the link is nearly saturated (~700Mbps).
Which one of these is best for this application (largest buffer on 10G ingress / 1G egress)?
CCR1009-8G-1S-1S+ (can’t find this one on mikrotik.com - was it phased out?)
RB4011iGS+RM
CRS305-1G-4S+IN
On the CRS better to use HW offload (buffer size limited by switch chip) or software bridging (is CPU good enough for 1 gigabit of traffic)?
Bridging only two ports so fast-forward should work.
Leave only-hardware-queue default or specify some other queue type?
Recommended queue configuration for traffic shaping on bridge (fully transparent, no rules for IP addresses etc. just handle all Ethernet frames equally) to limit traffic (10G->1G direction only) to ~800Mbps and minimize bursts?
