Thx for your post, i think i figured out your components.
In germany it seems a little bit tricky to get all components at a single provider.
As it looks nearly the same: would it be possible to use a netmetal 5 with the same minipcie card for indoor usage? Havnt found i inside look for the netmetal 5 yet. Do i need extra antennas for 5 ghz or are they included already ?
Do the extra antennas for the 2,4 ghz fit into the case ?
