We use the MTI 23dBi dual-pol for short links and it’s a great antenna. Two other options are the Gabriel dishes and drums. The drums are great when you have local noise (Same tower, nearby tower) but are twice as expensive as the dishes of the same gain.
On the 28dBi MTI panel, we’ve heard reports and seen one have water intrusion that takes down the link.
Thanks for the reply!
Yes we’ve tested the MTI 23dBi dual-pol flat panel and it works great in the lab even at full speed 80Mbps HDX and 60Mbps+ FDX.
Not tested Gabriel, that sounds a good tip - thanks very much
Anyone else with good/bad/ugly experiences ?
60Mbps+ FDX was 2 radio cards, Turbo, 5GHz band, Nstreme2 using our AMD ‘NX’-powered outdoor-grade HPR boxes.
It IS possible to go faster, there is a doc on our site showing 200Mbps bridged throughput P2MP with 5 radio cards in one HPR box as the BS.
Probably better to start a new thread about that, original here is about dual-pol Antennas -
We’ve been using RadioWaves and Gabriel dual polarity antennas for years with Trango gear. Both brands appear to be equal in overall performance. I like both, but the Gabriel typically comes in at a better price.
Regarding the MTi DP 23dBi panel…sure would be nice to see CableFree Solutions to offer that package as a DP client radio or NStreme2 PtP kit. With the MTi enclosure that could be a pretty slick product. Any plans to offer this?
Thanks for the feedback on Radiowaves and Gabriel. We too got quotes for both, Gabriel is cheaper and much shorter quoted lead time.
Are you using them for “full duplex” modes with Trango? Or just for “polarity hopping”?
I ask the question because “full duplex” puts a lot greater demand on the cross-polar isolation particularly at high modulation rates where C/I is key -
Very interesting you should ask the question about integrated antenna H/V switchable products. We have been giving this thought for a while. There is no doubt we can do this, and the obvious benefit that an operator can flick polarity remotely in case of interference, ducting etc. The downsides are price (significant but not appalling) and size (dual-pol MTI is larger). I know from debate elsewhere very few equipment vendors support that, or seem interested.
Comments from other users/operators on this is welcome -
Intresting subject
I have big problems with my antennas, for my PtP links ,so i did a crasy thing. I did take a Stella Doradus feeder and i put it in a IKEA metal Bowln and guees what! i did get a perfect antenna i have 24-26 dbi compered to a solid parabolic. But i did get rid of the inteferens from the other antennas from the Tower.The antenna looks like a drum antenna.
so i have tryed the antenna for 20 km and i workt perfect.
I can put up some pictures if somone is intrested:-)
I had real problems getting 2 signals to pass through 2 different sets of Radiowave dual-pol parabolics and we have had problems with there 24db flat panels. Interested in trying some of the 23db MTI dual-pol antennas. Anyone know a good supplier who has stock?
