how make best filter to avoid conflict ip… in the network?
To avoid ip conflicts on the network, first step is the basic - plan the network and write/log ip address’s used and where, then before adding a new address use in winbox tools
/tool ip-scan
This will give you a quick display of what ip’s are used in your network with the ip range and interface specified in the scan
