Maybe the title itself is not related to the issue I’m currently having, but I was wondering what settings would be best to set on my hAP ac3 with the WifiWave2 package enabled so that it’s compatible the most with most of devices that has been released for the past 6-7 years?
As of right now I know that Samsung A32 5G, A33 5G, OnePlus 8 and a couple of old laptops don’t have any issues, but Honor 50 throws up an exclamation mark and moves to mobile data for the internet. Now I don’t see yet why that happened and I’ve just enabled the debug logging which might show some more issues, but idk why it is happening in the first place, I’m assuming it might be because the SSIDs for both 2.4 GHz and 5GHz being the same and it trying to roam about might cause it some issues… but it worked well with the old hAP AC which I’ve replaced with it couple of days ago.
I didn’t yet try too much and I plan to try out more tomorrow, but it’s already late and I’m hoping maybe someone already knows the answer to such issue, and am still curious at what settings would be best for as little intervention as possible. I will try trying out different settings tomorrow.
It’s a very clean spectrum, a house with 2 floors and plenty of distance between houses.
Here’s my config
[admin@VE156_Kat_hAPac3] > export compact
# mar/24/2023 00:28:18 by RouterOS 7.8
# software id =
# model = RBD53iG-5HacD2HnD
# serial number =
add name=bridge_Guest
add name=bridge_Private protocol-mode=none
/interface vlan
add interface=bridge_Private name=vlan100_MGMT vlan-id=100
add interface=bridge_Private name=vlan201_Guest vlan-id=201
add interface=bridge_Private name=vlan202_IoT vlan-id=202
/interface wifiwave2 security
add authentication-types=wpa2-psk disabled=no name=Private
add authentication-types=wpa2-psk disabled=no name=Guest
set [ find default-name=wifi1 ] channel.band=2ghz-n .frequency=2412 .width=20mhz configuration.country="United States" .mode=ap .ssid=\
Private .tx-power=23 disabled=no name=wifi2_Private security=Private
set [ find default-name=wifi2 ] channel.band=5ghz-ac .frequency=5180 .width=20/40/80mhz configuration.country="United States" .mode=ap \
.ssid=Private .tx-power=23 disabled=no name=wifi5_Private security=Private
add configuration.mode=ap .ssid=Private5GHz disabled=no mac-address=0A:55:31:F9:69:90 master-interface=wifi5_Private name=\
wifi5_Private_Dedicated security=Private
add configuration.mode=ap .ssid=Guest disabled=no mac-address=0A:55:31:F9:69:8E master-interface=wifi2_Private name=wifi2_Guest \
security=Guest
add configuration.mode=ap .ssid=Guest disabled=no mac-address=0A:55:31:F9:69:8F master-interface=wifi5_Private name=wifi5_Guest \
security=Guest
/system logging action
set 0 memory-lines=5000
set 1 disk-file-count=5
add bridge=bridge_Private interface=ether1
add bridge=bridge_Private interface=ether2
add bridge=bridge_Private interface=ether3
add bridge=bridge_Private interface=ether4
add bridge=bridge_Private interface=ether5
add bridge=bridge_Private interface=wifi2_Private
add bridge=bridge_Private interface=wifi5_Private
add bridge=bridge_Guest interface=vlan201_Guest
add bridge=bridge_Guest interface=wifi2_Guest
add bridge=bridge_Guest interface=wifi5_Guest
add bridge=bridge_Private interface=wifi5_Private_Dedicated
/ip dhcp-client
add interface=vlan100_MGMT
/system clock
set time-zone-name=Europe/Zagreb
/system identity
set name=hAPac3
/system logging
add topics=debug,wireless
