I’m in an apartment building (8 homes) where within the building the internet to the apartments is done using coax. For the current internet speed the providers offer, this is sufficient, however in the near future in our street glass fiber internet will be offered and most of the apartment would like to switch to 2-8Gbit speed connection to the internet. For the connection between the switchboard at the front door to the apartments, docsis 4 would theoretically work up to 6-8 Gbit but I’m afraid the current coax cable gives too much noise and errors and these high speeds will not be reached.
I’d be interested to know if there is a possibility to switch from cabled connections to wireless connections within the building. For outdoors there are various options to arrange for these type of connections, but for indoors I’m a bit lost. And most of the wireless products for indoors are omnidirectional instead of directional, which could theoretically improve the link speed and quality.
The problem of the building is that is has thick (medieaval) walls although floors are wood, no concrete in the building.
My question is which wireless devices would be most appropriate to arrange a connection between the switchboard at the front door and, lets say, an apartment on the 4th floor. The internet provider will deliver a router at the switchboard and the apartment owner arranges for his own router. Would wifi6 have sufficient penetration to pass 40cm thick brick walls? Are there other wireless techniques which could be used? What would be the highest speed which could be reached? Would it be a problem if several wireless devices are next to eachother in the same switchboard, like interference and so.
