I think you can be a consultant without being an expert on any possible scenario at any scale
In my case, I have deployed Wisp/Fisp Networks up to 20Gbps of total bandwidth
If you ask me about scaling on switching, core-router, cgnat-router, QoS-Router, PPPoE-router, at that scale on MikroTik equipment I can solve it for sure
I am happy that most people (Specially Forum Guru and Forum Veteran) here are reading my signature and suggesting me for my own Query
FYI I am trying to workout a cheaper solution for one of my client and I created this post so if anyone who has already used some Hardwares like CRS or RB series for MPLS and What is the Performace they are getting from it.
Also there is no docs and forum topic available which describes the Capacity of Hardware Running MPLS…
But I didnt Know that this forum only helps Begineers… Well anyhow thanks for the recommendation @BartoszP@Znevna
Start with https://mikrotik.com/product/rb5009ug_s_in#fndtn-specifications with SRP @ 220$ which is not too high.
Make tests and then decide if you need to upgrade the router or not. 2004, 2216, 1036, 1072 … lots of possibilities.
IMHO combined 8Gb needs SFP+
For prod and those speeds, we tend to use the CCR1036 on ROSv6 long term for client ISPs.
CCR2216/2116 and CCR2004 are all capable of those speeds but they are still finding and fixing MPLS bugs in ROSv7 (one I submitted was just fixed in July) so make sure you’ve tested the protocols you want to run on ROSv7 hardware in a lab before you go prod.
Are you wanting just P functionality or do you need PE as well?
