Best hardware requirements
Config
Basically I am making one router 130 separate routers.
So on the router will be configured with
130 different /24 subnets (192.168.0.0/24 - 192.168.130.0/24)
Router will be the gate way for each subnet (192.168.0.1/24 -192.168.130.1/24)
dhcp servers for each subnet pushing out about 20 addresses
vlans for each of the 130 subnets, injecting them into switches where they will be striped out
queues for each subnet restricting them to roughly 3Mbps each
Taking all that into consideration would an RB800 be enough or should I build an x86 platform?
How much total bandwidth are you going to provide to the 130 subnets?
roughly 100Mbps with fiber like packet throughput.
