Hello
I have 4 pppoe clients each 2 from different sources ( different public ip and different dns )
what is the best way to loadbalance configuration .
Read the manuals, and search elsewhere on this forum.
This topic is well covered.
But because I have too much time on my hands here is a hint: PCC, Static Router Check Gateway and OpenDNS or Google Public DNS
Alex
thank u so much ,it is useful advice, but My problem lies in the DNS and routes .
Your problem lies in dns and routes because you have not followed my hints above.
check out this post of mine.
http://forum.mikrotik.com/t/more-control-over-pcc-load-balancing/38895/1
at the time I had 4 PPPoE connections. this worked out great.
now ,yes.
thanks alex ,thanks dboillot.
