Best LTE Router (based on your experience)
Hi all,
I’m looking for the best (based on your experience) LTE router that can be connected to hAP AC (RB962) to keep a persistent internet connection. I know it is very subjective so I would appreciate a few words to support your claim.
I am looking for answers based on personal experience.
Also, if you recommend another hardware setup (PCIe + router etc.), I’m more than happy to listen to your experience and recommendations.
Thanks a bunch,
Krzysztof
few days ago my customer have very interesting order. He has LTE sim card and have one cisco 2960G. For this setup i used rb912UAG-5HPnD. And then i made on ethernet port vlans/firewall. I prefer make shaping directly on switch. This configuration was cheap and it is still mikrotik
Hi Kurosudo,
am looking something for a small business - 2 people with 5-6 network devices. It should be robust, but on the cheap side.
We use RB960PGS with Huawei E3372h with great success… gl
Can we use RBwAPR-2nD&R11e-LTE as modem/router for 4G/LTE connection ?
I bought one and tested it on T-Mobile in the US.
After I added the APN… the unit connected to the T-Mobile Network and worked like any other Mikrotik router. I used the wireless on it and it was a typical 2.4 Ghz radio.
I went back in and set the unit to something like “passthrough”. One I did this… the Tik connected and passed the IP from the ISP to my computer like a modem.
So I am looking to try an install with the wAP LTE as a Modem only. Just have not had a chance yet.
I have been using Cradlepoint for years. The Cradlepoints have a LTE Advanced Modem. So if LTE Extreme comes to the city… the cradlepoint can get a faster connection.
On the wAP LTE… it has 3G and 4G. So its MORE LIKELY to connect when moved around like on “the taco truck”.
Thanks for update gotsprings!!!
I was looking something modem/router 4g/lte based on mikrotik (2in1) for remote client to get connected to internet without dedicated 4g/lte modem + extra tik router.
So i am guessing i will need to try same setup like you have and see how it goes. Hope it will work.
Connect ether1 to a switch.
Connect you computer to that switch.
You get a 192.168.88.0/24 address and a fully functional router.
Procure the right sized Sim and activate it.
Go into the LTE interface, and add the ISP/carrier APN…
Then I was connected.
If the wAP LTE were 10/100/1000 and had one of the newer processors… I could see this… with a managed switch to be a router with a wired ISP as the primary. Then rolling over to cellular when needed.
What about this SXT LTE kit ? Could this be used too for the same purpose ?
SXT has dual Sims. But no WiFi.
So SHOULD???
Ok this would not fit my purpose (2in1). But as i got some information it will be good for rural area to get connected to 4g/lte. Thanks again gotprings for nice conversation. Now i have all answers.
