Best matcher
I need to do gateway load balancing with 3 DSL connections, 2 on one ISP and one on other ISP.
If on firewall mangle I will match http traffic firstly
add action=mark-connection chain=forward comment=“HTTP and HTTPS” disabled=no
dst-port=80,443 new-connection-mark=HTTP_HTTPS passthrough=yes protocol=
tcp
add action=mark-packet chain=forward comment=“” connection-mark=HTTP_HTTPS
disabled=no new-packet-mark=HTTP_HTTPS passthrough=no
and PCC match roules after for gateway load balancing,
/ ip firewall mangle
add chain=input in-interface=wlan1 action=mark-connection new-connection-mark=wlan1_conn
add chain=input in-interface=wlan2 action=mark-connection new-connection-mark=wlan2_conn
add chain=output connection-mark=wlan1_conn action=mark-routing new-routing-mark=to_wlan1
add chain=output connection-mark=wlan2_conn action=mark-routing new-routing-mark=to_wlan2
add chain=prerouting dst-address=10.111.0.0/24 action=accept in-interface=Local
add chain=prerouting dst-address=10.112.0.0/24 action=accept in-interface=Local
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:2/0
action=mark-connection new-connection-mark=wlan1_conn passthrough=yes
add chain=prerouting dst-address-type=!local in-interface=Local per-connection-classifier=both-addresses:2/1
action=mark-connection new-connection-mark=wlan2_conn passthrough=yes
add chain=prerouting connection-mark=wlan1_conn in-interface=Local action=mark-routing new-routing-mark=to_wlan1
add chain=prerouting connection-mark=wlan2_conn in-interface=Local action=mark-routing new-routing-mark=to_wlan2
will HTTP matcher work for prioritizing HTTP traffic.
Who is the best way in this case to use for matching NTH or PCC?
thank you.
There are loots of thing that can be done with TCP port 80 and only one of them is HTTP.
And what have PCC to do with prioritizing.
It has not to do with prioritization, but with traffic matcher yes.
For prioritization it firstly I must match it. am I wright?
