I am trying to figure out which Load Balancing method is best for combining 10 equal WAN into single Uplink. What I tried is to use PCC and simple firewall marking method but it looks like I lose almost 25-30% of the total traffic.
I have 10 physically separate WAN with equal speed; 100 Mbps. I would appreciate to know which method is best for me to gain maximized speed without any interruption on my customers.
Thanks in advance.
anav
January 24, 2022, 12:10pm
2
PCC load balancing… if done correctly should work.
However what is the device doing the work ??
Hi, thanks for reply.
I have tested with CCR1036-12G-4S with both ROS6 and ROS7. My sample config for ROS6 can be seen below;
add address=192.168.100.1/224 network=192.168.100.0 interface=LAN
add address=192.168.1.1/30 network=192.168.1.0 interface=ether1
add address=192.168.2.1/30 network=192.168.2.1 interface=ether2
... to 10.1 - ether10
/ip firewall mangle
add chain=prerouting dst-address=192.168.1.0/30 action=accept in-interface=LAN
add chain=prerouting dst-address=192.168.2.0/30 action=accept in-interface=LAN
... to 10.0/30
/ip firewall mangle
add chain=prerouting in-interface=ether1 connection-mark=no-mark action=mark-connection new-connection-mark=ISP1_conn
add chain=prerouting in-interface=ether2 connection-mark=no-mark action=mark-connection new-connection-mark=ISP2_conn
... to ether10 - ISP10_conn
/ip firewall mangle
add chain=prerouting in-interface=LAN connection-mark=no-mark dst-address-type=!local per-connection-classifier=both-addresses:10/0 action=mark-connection new-connection-mark=ISP1_conn
add chain=prerouting in-interface=LAN connection-mark=no-mark dst-address-type=!local per-connection-classifier=both-addresses:10/1 action=mark-connection new-connection-mark=ISP2_conn
... to 10/9 - ISP10_conn
/ip firewall mangle
add chain=prerouting connection-mark=ISP1_conn in-interface=LAN action=mark-routing new-routing-mark=to_ISP1
add chain=prerouting connection-mark=ISP2_conn in-interface=LAN action=mark-routing new-routing-mark=to_ISP2
... to ISP10_conn - to_ISP10
add chain=output connection-mark=ISP1_conn action=mark-routing new-routing-mark=to_ISP1
add chain=output connection-mark=ISP2_conn action=mark-routing new-routing-mark=to_ISP2
add chain=srcnat out-interface=ether1 action=masquerade
add chain=srcnat out-interface=ether2 action=masquerade
... to ether10
add check-gateway=ping distance=1 gateway=192.168.1.1 routing-mark=to_ISP1 scope=255
add check-gateway=ping distance=2 gateway=192.168.2.1 routing-mark=to_ISP2 scope=255
... to to_ISP10
add check-gateway=ping distance=1 gateway=192.168.1.1 scope=255
add check-gateway=ping distance=2 gateway=192.168.2.1 scope=255
... to distance=10 - 10.1
