# Best method to load balance 2 internet line?
**URL:** <https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337>\
**Category:** General\
**Created:** [April 28, 2010, 9:48pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337 "2010-04-28T21:48:37Z")\
**Posts on this page:** 20\
**Page:** 1
<div class="post-metadata">
**Author:** ![bootchi](https://forum.mikrotik.com/letter_avatar/bootchi/32/6_449c533f586939b6e5f246632a46421f.png) [@bootchi](https://forum.mikrotik.com/u/bootchi)\
**Post date:** [April 28, 2010, 9:48pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/1 "2010-04-28T21:48:37Z")
</div>
hi all i asked for the best method to loadbalance two internet line each one is 4 M
1- pcc or
2-nth
i have mk ver 3.30
please help me to choose the better way
**Author:** ![fewi](https://forum.mikrotik.com/letter_avatar/fewi/32/6_449c533f586939b6e5f246632a46421f.png) [@fewi](https://forum.mikrotik.com/u/fewi)\
**Post date:** [April 28, 2010, 10:25pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/2 "2010-04-28T22:25:14Z")
</div>
PCC is better.
**Post date:** [April 29, 2010, 3:55am UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/3 "2010-04-29T03:55:26Z")
</div>
thanks for you
what a bout NTH
I want to know the advantages of each method
**Author:** ![Chupaka](https://forum.mikrotik.com/user_avatar/forum.mikrotik.com/chupaka/32/215_2.png) [@Chupaka](https://forum.mikrotik.com/u/Chupaka)\
**Post date:** [April 29, 2010, 11:29am UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/4 "2010-04-29T11:29:44Z")
</div>
PCC can behave like Nth, and can do balancing in smarter way (depending on classifier)
PCC don’t waste connection-mark, so you can use it for other purposes
does anybody knows advantages of Nth? except it works on v3.20 😃
**Author:** ![Ibersystems](https://forum.mikrotik.com/user_avatar/forum.mikrotik.com/ibersystems/32/196_2.png) [@Ibersystems](https://forum.mikrotik.com/u/Ibersystems)\
**Post date:** [April 29, 2010, 1:22pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/5 "2010-04-29T13:22:05Z")
</div>
Hi Chupaka! My problem with PCC is that I need a script to watchdog my ADSL lines, and if one line have problems reconfigure the PCC to avoid problems with the connections.
Do you have something made to solve this?
thanks!
**Post date:** [April 29, 2010, 1:25pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/6 "2010-04-29T13:25:10Z")
</div>
AFAIR, there were such script posted about a month ago or something…
**Author:** ![void](https://forum.mikrotik.com/letter_avatar/void/32/6_449c533f586939b6e5f246632a46421f.png) [@void](https://forum.mikrotik.com/u/void)\
**Post date:** [April 29, 2010, 1:35pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/7 "2010-04-29T13:35:15Z")
</div>
Just mark your connections using PCC and then put a routing mark on them.
Then add default backup routes for all the different routing marks with a higher distance over the other DSL lines.
If there are troubles with your DSL just disable your PPPOE client (or interface) and PCC will work over the other lines.
**Post date:** [April 29, 2010, 1:44pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/8 "2010-04-29T13:44:32Z")
</div>
> [@void](#):
This don’t work, becaume my adsl routers will be connected with my routeros and this conection will work, but not my pppoe in router.
**Post date:** [April 29, 2010, 1:51pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/9 "2010-04-29T13:51:09Z")
</div>
> [@Ibersystems](#):
So how do you decide your ADSL connection has problems ? You want to ping something or … ?
**Post date:** [April 29, 2010, 2:02pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/10 "2010-04-29T14:02:28Z")
</div>
[http://forum.mikrotik.com/t/solved-script-to-recreate-the-load-balance-mangle-rules/36203/1](http://forum.mikrotik.com/t/solved-script-to-recreate-the-load-balance-mangle-rules/36203/1)
this is a post with the script, but I think this is using pppoe in the routeros. My networks use other routers that make the pppoe connections.
thanks,
**Post date:** [April 29, 2010, 2:04pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/11 "2010-04-29T14:04:25Z")
</div>
> [@void](#):
> > [@Ibersystems](#):
Void,
I decide if my adsl works if my pings works across this “ADSL1” line. You can test it with a ping using out-interface for this ping ADSL1 or ADSL2, etc..
**Post date:** [April 29, 2010, 2:09pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/12 "2010-04-29T14:09:24Z")
</div>
I used this BIG script for NTH months ago.. to make this, but is not inmediatly. You have to run every 5 minutes or so, and you could have your system this time working bad. This is for 2 lines, for 4 lines you need 16 scripts to work like this.. SORRY FOR THE \n and \r but I copy paste my rsc.
```plaintext
/system script
add name=TESTADSLSCRIPT policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff source="#SCRIPT MI\
    RAR ESTADO ADSLs#\r\
    \n\r\
    \n#set variables\r\
    \n:local pingcount 3\r\
    \n:local ipA 192.168.7.2\r\
    \n#ADSL1\r\
    \n:local GatewayA 192.168.7.1\r\
    \n:local ipB 192.168.8.2\r\
    \n#ADSL2\r\
    \n:local GatewayB 192.168.8.1\r\
    \n:local website www.google.com\r\
    \n\r\
    \n\r\
    \n#ping gateways with src\r\
    \n:local pingresultA [/ping \$website src-address=\$ipA count=\$pingcount]\
    \r\
    \n:local pingresultB [/ping \$website src-address=\$ipB count=\$pingcount]\
    \r\
    \n\r\
    \n\r\
    \n:if ((\$pingresultA=0) && (\$pingresultB>0)) do={ /system script run ADS\
    L1FALLA; :log warning \" Falla ADSL1\" }\r\
    \n\r\
    \n:if ((\$pingresultA>0) && (\$pingresultB=0)) do={ /system script run ADS\
    L2FALLA; :log warning \" Falla ADSL2\" }\r\
    \n\r\
    \n:if ((\$pingresultA=0) && (\$pingresultB=0)) do={ /system script run FAL\
    LANTODASADSL; :log warning \" Fallan todas las ADSL\" }\r\
    \n\r\
    \n:if ((\$pingresultA>0) && (\$pingresultB>0)) do={ /system script run FUN\
    CIONANTODASADSL; :log info \" Funcionan todas las ADSL\" }\r\
    \n"
add name=FUNCIONANTODASADSL policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff source="#SCRIPT SI\
    LAS DOS FUNCIONAN BIEN#\r\
    \n/ip firewall mangle set [find comment=\"ADSL1 CONN\"] disabled=no;\r\
    \n/ip firewall mangle set [find comment=\"ADSL2 CONN\"] disabled=no;\r\
    \n/ip firewall mangle set [find comment=\"Marca la ruta como ADSL1GW\"] di\
    sabled=no;\r\
    \n/ip firewall mangle set [find comment=\"Marca la ruta como ADSL2GW\"] di\
    sabled=no;\r\
    \n/ip firewall mangle set [find comment=\"Conexiones del router de la red1\
    \"] disabled=no;\r\
    \n/ip firewall mangle set [find comment=\"Paquetes del router de la red1\"\
    ] disabled=no;\r\
    \n/ip firewall mangle set [find comment=\"Conexiones del router de la red2\
    \"] disabled=no;\r\
    \n/ip firewall mangle set [find comment=\"Paquetes del router de la red2\"\
    ] disabled=no;\r\
    \n/ip route set [find comment=\"TRAFICO DEL ROUTER Y TRAFICO SIN MARCAR1\"\
    ] gateway=\$GatewayB;\r\
    \n/ip route set [find comment=\"TRAFICO DEL ROUTER Y TRAFICO SIN MARCAR2\"\
    ] gateway=\$GatewayA;\r\
    \n:log info \"Se ha ejecutado el script de 2 ADSL ok\";\r\
    \n"
add name=FALLANTODASADSL policy=\
    LAS DOS ADSL FALLAN#\r\
    \n/ip firewall mangle set [find comment=\"ADSL1 CONN\"] disabled=yes;\r\
    \n/ip firewall mangle set [find comment=\"ADSL2 CONN\"] disabled=yes;\r\
    sabled=yes;\r\
    sabled=yes;\r\
    \n#/ip firewall mangle set [find comment=\"Conexiones del router de la red\
    1\"] disabled=yes;\r\
    \n#/ip firewall mangle set [find comment=\"Paquetes del router de la red1\
    2\"] disabled=yes;\r\
    \n#/ip firewall mangle set [find comment=\"Paquetes del router de la red2\
    \n#/ip route set [find comment=\"TRAFICO DEL ROUTER Y TRAFICO SIN MARCAR1\
    \"] gateway=\$GatewayB;\r\
    \n#/ip route set [find comment=\"TRAFICO DEL ROUTER Y TRAFICO SIN MARCAR2\
    \n:log info \"Se ha ejecutado el script de ADSLs FALLAN\";\r\
    \n/system script run ERROR;"
add name=ADSL1FALLA policy=\
    ADSL1 FALLA#\r\
    sabled=yes;\r\
    sabled=yes;\r\
    \n:log info \"Se ha ejecutado el script de ADSL1 FALLA\";\r\
add name=ADSL2FALLA policy=\
    ADSL2 FALLA#\r\
    sabled=yes;\r\
    sabled=yes;\r\
    \n:log info \"Se ha ejecutado el script de ADSL2 FALLA\";\r\
**Post date:** [April 29, 2010, 2:57pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/13 "2010-04-29T14:57:45Z")
</div>
Martin, on PL MUM, Valens said something about ‘scope’ and ‘target-scope’ for checking remote addresses… maybe one should ask him for details? =)
**Post date:** [April 29, 2010, 3:36pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/14 "2010-04-29T15:36:16Z")
</div>
yes,
I talked with Valens and I did tests here in the office, but I didn’t arrive to nothing.
What mxena said is that I can ping to google and microsoft (or whatever “always” will work) and mark this ping destinations with a routing mark.. and then, as this pings always should use the same ADSL route.. in my case ADSL1 or ADSL2, then I can use the watchdog to enable or disable rules for PCC with up and down scripts. Do you understand what I try to do?
**Post date:** [May 1, 2010, 8:07pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/15 "2010-05-01T20:07:09Z")
</div>
huhuh! real-life testing required, but in the lab all seems fine…
let’s suppose we have 192.168.1.1 as a modem1 address, 192.168.2.1 as a modem2 address. 1.1.1.1 and 2.2.2.2 are fake addresses - they don’t exists nowhere, are used only for recursive routing building
we’ll check using 213.180.204.3 and 93.158.134.3 (those are [ya.ru](http://ya.ru) website)
```plaintext
add dst-address=213.180.204.3/32 gateway=192.168.1.1 scope=10 target-scope=10
add dst-address=93.158.134.3/32 gateway=192.168.2.1 scope=10 target-scope=10
add dst-address=1.1.1.1/32 gateway=213.180.204.3 scope=30 target-scope=10 check-gateway=ping
add dst-address=2.2.2.2/32 gateway=93.158.134.3 scope=30 target-scope=10 check-gateway=ping
add gateway=1.1.1.1 routing-mark=ISP1 scope=30 target-scope=30
add gateway=2.2.2.2 routing-mark=ISP2 scope=30 target-scope=30
add distance=10 gateway=2.2.2.2 routing-mark=ISP1 scope=30 target-scope=30
add distance=10 gateway=1.1.1.1 routing-mark=ISP2 scope=30 target-scope=30
now, if both 213.180.204.3 (via 192.168.1.1) and 93.158.134.3 (via 192.168.2.1) are reachable, ‘ISP1’ routing table uses 192.168.1.1, ‘ISP2’ uses 192.168.2.1 as default gateway. if one of 213.180.204.3/93.158.134.3 stops responding to ping, all traffic is routed to another modem
comments are welcome =)
**Post date:** [May 1, 2010, 8:55pm UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/16 "2010-05-01T20:55:23Z")
</div>
I’ll try in ten days, when I return to the office.
Thanks!!!
**Post date:** [May 2, 2010, 12:04am UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/17 "2010-05-02T00:04:10Z")
</div>
oops, I don’t exactly remember where I have got this fake addresses in my investigations, but actually they are not needed - it’s maybe just more beautiful (and easy-to-change) to use them ))) below is ‘lite’ version 😃
```plaintext
add gateway=213.180.204.3 routing-mark=ISP1 scope=30 target-scope=30 check-gateway=ping
add gateway=93.158.134.3 routing-mark=ISP2 scope=30 target-scope=30 check-gateway=ping
add distance=10 gateway=93.158.134.3 routing-mark=ISP1 scope=30 target-scope=30 check-gateway=ping
add distance=10 gateway=213.180.204.3 routing-mark=ISP2 scope=30 target-scope=30 check-gateway=ping
**Post date:** [May 13, 2010, 8:09am UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/18 "2010-05-13T08:09:08Z")
</div>
Mmm. This is working fine with google and microsoft ips.. but:
My router is now making ping to google and microsoft.. 24x7.. what can they do if they look this extrange infinite ping?
We can make a script to change the IPs every 24 hours but I don’t know if it’s necessary.
How many pings make the check gateway option in a minute? it’s possible to set how many seconds between pings?
Thanks,
**Post date:** [May 13, 2010, 9:31am UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/19 "2010-05-13T09:31:51Z")
</div>
just relax - the best half of the world pings those servers twenty four hours a day, they won’t notice you =)
also, you may use some nearer sites: some of your ISP devices, for example…
**Post date:** [May 13, 2010, 9:38am UTC](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337/20 "2010-05-13T09:38:07Z")
</div>
aaaaaaaargh, I have to give you a Karma. Catching you will be very difficult.. xD
thanks, this works very well for 3 hours, we will try it all this week.
[Next page](https://forum.mikrotik.com/t/best-method-to-load-balance-2-internet-line/37337.md?page=2)
