Who have experience with equipment in high noise region? Right now I’m in very bad situation with CM9 on 2,4 GHz, becouse in my region there’s about 30-40 active AP’s on aproximately every 500m. (2-3 APs on each channel)
Prism Chipset culd run better than atheros in this situation…
For Example Senao NL 2511+ (802.11b)
Regards
I would install cavity filerss to eleminate youir receiver having to deal with the noise out side of the channel of interest. Ore your customers reregistering rapidly?
yes, but ping goes from 100-10 000 ms
better use 802.11g miniPCI in high noise.
the problem you have is threated many times in this forum.
regards,
C. G.
