Best option for a SOHO load balancing 2-WAN port
Hello!
I would like a little advice in which router to buy.
I need to configure the MikroTik Router as a network balancer, connecting 2 ISP, and performing load balancing so that I can use the maximum throughtput. On one ISP I have a 100/10MB connection, and with the other ISP I expect to have 50/10MB.
I would need some ethernet ports (obviously), WiFi capable is a plus, and it’s also a big plus that the MikroTik can PoE in and also PoE out, because I will connect one radio to serve some clients near in the area.
Also I would like that you share your experience using that models you’ve told me.
Thank you a lot!
Sergio F.
Hello, this rb http://routerboard.com/RB2011UiAS-2HnD-IN is verry good.
I have made an configuration for that on my website.
Wireless interface must to be configurated
http://www.wirelessinfo.be/index.php/mikrotik/pages/confige
See configuration 5
Greatings
Thank you for your suggestion, and also thanks for sharing with me your webpage!
