best performance link
how to setup best performance for AP in mikrotik, so link can be past a biggest data
regards
Your performance has more to do with the CPU of your router, and the client’s signal strength/link speed.
Make sure you use a channel with very little interference, and your CPU load is not too high. There’s no simple answer for your question. Every link is unique.
