Dear all,
I am quite sure that this use-case was already discussed many times before, but unfortunately I wasn’t able to find a best practice solution for my use case.
I want to use my two mikrotik routers (HAP AC lite =AP_02 and HAP AC =AP_01) as wireless bridge on the 5GHz Channel and they should as act as normal AP on the 2,4Ghz Channel.
Both routers has two Atheros wifi cards with 5 and 2,4 GHz.
Below you’ll find a schematic of the network layout.
The configuration is already working, but i am not sure that this is the suitable solution for my use case.
Requierment:
- We have tablets (different OS) and smart phones (different OS) therefore a smooth roaming between AP_01 and AP_02 is important
- wifi range should be maximized
- Fileserver and DHCP-Server in the same physical network as AP_01, DHCP should distribute addresses also for devices connected to AP_02
Mikrotik OS enables many possible solutions (Wireless mode: ap station, station-pseudobridge, station WDS; WDS Mode: disabled, dynamic, static, …; Nstreme?), but which setup will be the best for my purpose.
Thanks in advance!
BR
Michael
