Best Practices?
I’ve just received a RB751G-2HnD and noticed that the default config is to create a bridge port on ether1 and wan1 then set the ip addresses on the bridge port for the lan, on the RB433’s we’ve had I did the same but instead set the ips up on the bridge port i set set then up on ether1 (still had to create a bridge port for wireless to work).
Not sure if it makes a huge different but thought it was best to ask.
Thanks,
Chris
You should always set up IP Address on Bridge Interface instead on Bridge Port
