Hi Mikrotik folks,
I am currently using Mikrotik CCR1036-12G-4s to Load Balancing 5 WAN interfaces PCC method. my network is consuming more than 900Mbps. Recently I noticed that one or two cores are always 95% load, especially when I am using more than 10 prerouting in Mangle. as you know that this router board mounted with 36 cores x 1.2GHz CPU, but though to lack of multi threading management on my case, the script is always using one or two cores which is disaster. what is the best router board you suggest to use in my case? core speed VS core numbers? If I moved to rb1100AH4x for example would it be better or worse?
