Best routerboard for wifi delivery in camping park
I have been made some tests with RB951-2hnd, indoor and outdoor tests. The RG951-2hnd can handle several users in wifi card with nice speeds. 50 to 60 users with 2mbits/512k but the outdoor cooverage is a bit strange.
What kind of routerboard with / without case do you recoment to setup in a camping park to support maximum possible users at wifi ( just wifi card enabled with bridging for ethernet, no routing/net/connection tracking).
I need to handle a few clients, 1000 + with several units at 2.4(Country regulation to 100mw max) and 5ghz(contry regulation to 1000mw max)
Any sugestions ? I know that RB951-2hnd is very good, but i need also a good routerboard with external antenas, omni/base station.
I use groove + a smallish gain omni antenna. Working fine for me but I dont have your number of users.
Thanks for sugestion, i tried a few grooves in past but they get very loaded, cpu 100% and slow bandwidth, the rb951 is a bit better, but is not for outdoor.
try Groove 52 as it has more CPU power than the old Groove.
I’m going to test a RB912UAG-2HPnD in an 3rd party enclosure ( StationBox S ) as an outdoor AP. just waiting for the antenna (2x2 mimo omni ).
This is what we do.
Good, normally 90% of the camping users only have bg, not n, but i think mikrotik supports bgn maybe.
What antennas do you use for that StationBox S with RB912UAG-2HPn?
thanks
even if the user is bg only it is not bad to have 2 antannas connected.
i have ordered http://www.wlan-shop24.de/24-GHz-WiFi-Omnidirectional-Antenna-Outdoor-2x2-MIMO-15dBi, at the moment i’m waiting for it. once i have it i will do some tests.
“n” in the product name mean - it supports 802.11n, however if router has 2GHz wireless it will support all thee of them - b/g/n also, in RouterOS each type of client will get as fast as it can get,11n clients will have maximal available speeds, while b/g will only have their rates available. Same goes for 5GHz - it will support 11a, in addition that it supports 11n
Hi jaykay2342,
Did you already test the RB912UAG-2HPnD with the outdoor antena, is it good, can it handle many users ?
I am testing an rb951g-2hnd inside an outdoor case in the camping park to see how it works outdoor, this rb951g is a piece of art for indoor, it work very very well :slight_smile:
Unfortunately we had some issues with the delivery of that antenna, due to this we had to freeze the project for the moment. i hope next week we can go onside again and finish the installation and start with testing.
