Hi all
anyone can suggest a table with the best values for some conditions? (e.g. if longer than this use this). Which is best?
Suggestion welcome ![]()
Hi all
Hello pdf,
I believe the framer-limit can be changed to give you best performance in noisy environment. It is quite in my neck of the woods so I change it 4000.
-Louis
