best setting
Hi All
I’ve connected 2 RB912-out units both have a dual feed parabolic dish
With this in mind what would be the best config
Setting tx on chain0 an rx on chain1 on do I set both chains active on tx and rx ?
In lab environment i got beter thruput on tx chain 0 an rx on chain 1, but don’t know if this will
Be the same when installed
Also using nv2 on 5ghz band
Tx any advise would be good
The chains are used one of two ways. Either they are trying to increase gain or they are passing separate data paths and there by increasing throughput. If you are not sure then check all TX and RX boxes. Generally speaking, this is the best practice for most situations most of the time. This will usually give you the best real world throughput results as well.
