Best to Clone / replace device
Hi!
I have a few questions about cloning / replacing routerboards.
Whats the easiest and correct way in the following scenarios?
1. Replace a device with new device of same model, because of defective hardware
Backup and restore? Export? Export Compact?
2. Make same configuration as another device, for example cloning AP’s or create a template if you usually configure devices for similar purposes.
Export Compact?
Regular Export + MilliScript
Easy!
Oh, nice tip, didn’t know about MilliScript, awesome =)
