I have to connect 2 distinct offices over the internet. Both locations has reserved Public IP. In the HQ there is a FTTB (100/100mbit) connection and there is a SQL server which hosts databases for accounting software named Comarch Optima.
In the another, smaller offcie (with only one person )there is GSM connection on LTE which is about 10/10mbps minimum.
Until now I have been using OpenVPN on the local computer and tried to connect to the HQ with OpenVPN for Windows client, but the application crashes. I suppose due to timeouts, as OpenVPN tunnnel is not fast enough ?
Now I would to connect theses networks with VPN at network level, there are 2 Mikrotik (with L4 license) routers on each side, with public IPs, even on GSM/LTE connection.
What kind of VPN do I need for optimizing SQL speed?
Any help would be more than appreciate…
Fastest is Wireguard if a VPN truly is needed. It claims to be 50% faster then OpenVPN.
But … caveat … only available in ROS7 version which still has not reached release state (however, Wireguard works stable as a rock on ROS7 !)
But I would first look into that LTE connection.
10/10 is really not that much. Besides, SQL connections can be really problematic for occasional ruptures of the link.
Proposal:
Is it possible to do remote desktop from the branch office towards the Main office using VPN ?
I already ran WVD to Azure on a measly 5mb connection (also using LTE).
Then there will be no disruption either if the line has an occasional hickup, everything will still work on the terminal server (or whatever remote desktop technology is being used).
Though running 7.1RC6, I would not advice to use it. @TS: what RouterOS version are you currently using on the MT’s? And what hardware? Why are you not using IPSEC over L2TP?
