i need a vpn between 2 Offices, but only one office have a static ip adress behind a firewall.
the uplink and downlink is on the office 2 1mbit and 4mbit
wath is the best vpn protocoll to connect the 2 offices.
Gre
Ipip
If security matter then “ipsec”
Sent from my SM-N920T using Tapatalk
my problem is, only one Site have a offical Public IP. the oder Site have a 3G LTE Uplink.
i need to conect forom any place bihind Firewalls.
now i use pptp, but the speed is verry slow.
SSTP, or L2TP better?
PPTP is faster comparing l2tp/sstp/openvpn.
I.e. questions are:
So you mean you have private address on LTE side ?
If yes you maye use script which is not defficult to find on google inorder to use DDNS address for the private address side such as LTE.
but if you will dynamic address through LTE but it is public you can use the Mikrotik cloud
Hello, thanks for the replay
I.e. questions are:
I Have Set MAX MTU and MRU to 1420 to have a mor stable connection.
I Use Mikrotik Cloud, butt Remot acces on 3G Devices is not Possible
I Have 1 Central with privat Public IP and to this any 3G Roter neeed to Connect it. so i have the possibiliti to conect to ech other network.
I need a stabe, fast speed VPN Connection.
thanks Markus
L2TP/ipsec or sstp
PPTP is efficient but you can only use L2TP over IPSec due to some routers limitations.
If VPN must be fast, then you should avoid all TCP solutions (only UDP are fast). http://sites.inka.de/bigred/devel/tcp-tcp.html
If it should be encrypted - (private data) - than you should consider IPSEC with IKEv2.
If you are only escaping from ISP’s NAT or looking for other unencrypted purposes, look at L2TP.
SSTP is usable (for example) to configuring devices in restricted firewall enviorment in secure way. SSTP is using TCP, so you can set port to 443 (yes, HTTPS port) to be sure that nobody (?)
will block it.
Why not give a try to Astrill, i have been using it for a while now. And it is performing really good.
Both IPSec and SSTP do not require both sides to have a static IP. For IPSec you’ll have to use the NAT-T option so IPSec packets are wrapped in a UDP packet.
In my experiences, IPSec is more tolerant of network issues. I use SSTP for site-to-site as well but then I have to use a script on both routers to consistently check (ping) the remote site to see if it’s still up, and if not, disable the interface for 5 seconds (which disconnects it). The client side router will reconnect after that. That script runs every 15 seconds.
SSTP and IPSec will likely perform the same, your bandwidth on the 3G site is the limiting factor. SSTP has acceptable performance for me.
Try for IPSec with NAT-T (UDP), fall back on SSTP.
Funny, most responders seems to recommend IPSec, but I doubt if any of them did even try it in circumstances like yours. Be careful when choosing IPsec if you want layer 2 (ISO OSI) site2site VPN (which is must in enviroment with AD, PXE deployment and so on) when one of the pears is behind NAT (without possibility to do port forwarding) with DHCP. You won’t be able to find any documentation for that case. Reason is simple - it cannot be done. Please correct me if I am wrong. I’ve heard it’s possible to do by encapsulating: EoIP on top of IPsec on top of PPTP (3 extra layers lol, I know how it sounds), but performance will suck (unfortunately I don’t tired it and I cannot offer you any numbers). I’d be ideal case for OpenVPN. Unfortunately, Mikrotik devs shot their foot by not implementing UDP/LZO in OpenVPN. In your case choosing routerboard was a bad choice. On the other hand you could also try it. OpenVPN @ routerboard with TCP (BAD transport - it’s important to understand it) it gives me 20-30 mbps @ 600 MHz MIPS (951 for example).
Wrong. It can be done - NAT-T and port forwarding, depending on which side is behind NAT.
Example, documentation? :>
Let’s say that IPSec’s initiator side is behind NAT with dynamic public address and WITHOUT possibility of doing port forwarding, do you state it’s possible?
For initiator side port forwarding is not required.
It is basic client/server setup with generate-policy on server side.
Trying to do a peer-to-peer tunnel will be problematic because you have to specify a peer IP address or hostname on both VPN endpoints. What do you specify on the one trying to connect to the device behind the NAT? The IP of the NATing device? Or the private IP of the VPN endpoint behind it? The second option is obviously wrong (because it will be an RFC1918 address or otherwise invalid), but the first option can’t be right either because you don’t want to peer with the public facing firewall/router, you want to peer with the device behind it. So…
[quote=princemoga post_id=667681 time=1528744879 user_id=123008]
What about windscribe?
Have you used it?
[/quote]
This Canadian-based VPN provider offers freemium software. The free version comes with a 10GB/month limit with many servers available on the premium version. For instance, Australia is not available as a server option in the free version.
I would suggest you to go for PureVPN. One of the best I have ever used. Currently, a friend of mine also got it for just $2.48 per month with a 2 years subscription. Moreover,
And no doubt it is one of the fastest vpn service available at the moment to buy. Windscribe stands at 15th whereas PureVPN stands at number 2
If you need something cheap and reliable I would recommend this vpn.
PureVPN is one of the worst possible VPNs you can choose if you care about security and privacy since they are infamous for logging and leaks.
I do not understand why people simply do not google a potential new service or product they want to use and type “productservicename bad” / “productservicename issues” / “servicename lies”. You’ll be shocked how you find issues that may or may not affect you and help you filter for what you actually want, while enabling you to understand that field a little more.
You will not find a single one recommending the Hong Kong VPN provider, PureVPN.
The best place to check a VPN review is Trust pilot. No one can match their rating. It scores 9.5/10 are the most trusted app.
coming back to the intial issue, I would like to contribute some technical facts.
You need to chose the VPN technology according to your limiting factors. These could be:
For me, there are three VPN technologies which stand the test for almost all scenarios. Of course there are several other VPN technologies, but either they are considered insecure or not implemented on RouterOS, so my selection is:
(L2TP)/IPsec
Pros:
Cons:
SSTP
Pros:
Cons:
GRE (over IPSec)
Pros:
Cons:
Of course the mentioned pros and cons are not complete. I focused on the in my opinion most important facts.
Okay, I’ll stop beeing a wise ass. To come back to the intial question: If you have one site connected by LTE you probably run into (C)NAT issues, so you need to bite the bullet and use SSTP.
If (C)NAT is no issue, use (L2TP)/IPsec. All VPN techologies add additional encapsulation (translates to overherad), and are therefore decreasing throughput and increasing latency. So using VPN with 1MBit/s will result in a slow(er) connection between the two sites and there is nothing you can do about it :-/
Regards,
Ape
