i need a vpn between 2 Offices, but only one office have a static ip adress behind a firewall.
the uplink and downlink is on the office 2 1mbit and 4mbit
wath is the best vpn protocoll to connect the 2 offices.
You can use IPIP or GRE tunnel with IPsec!
It will do the job perfectly
regards
to use ipsec dont you need only ip static?
No!
A simple script will fill in right address every time it changes..
Tested on numerous installations..
regards
