Best way connecting different subnet users
First of the question. What would be the best way to connect clients in different subnets in order for local LAN gaming and local LAN chat program? Only about 50% of client base need this, other 50% are fine as is. Know bridge will work, but maybe there would be a better way. Don’t need windows traffic on network.
My system setup. Gateway PC with mikrotik installed, connecting to internet on wan side using hotspot for internet access and accounting. On LAN side connect with LAN to 333 board that connect dual Nstream to tower with another 333 board connecting through LAN to five 532 set up as access point’s. Client CPE that is 133 boards connect as station to these access points. Every thing is routed and running good. Each client CPE is set up to supply user computers with ip through DHCP different subnet range, for routing.
Any ideas?
