Best way to check whether [find] yields results?
Because I can never remember how this works, I find myself using the following expressions interchangibly in order to determine whether one or more matching items exist:
    :if ([:len [/interface find name=$interfaceName]] > 0) do={
    :if ([/interface find name=$interfaceName] = "") do={
    :if [/interface find name=$interfaceName] do={
I would like to use the last option, but I don’t know whether it always works as expected, nor whether these are exactly equivalent.
Edit: Although I apparently can’t invert the last option easily, because I “cannot logically negate nothing”. Second option is just awkward. First option is a little long, but feels the most robust, as one would expect [find] to always return an array of results.
The correct method is only the first.
:if ([:len [/interface find where name="the name"]] > 0) do={} else={}
# or if used with print
:if ([:len [/interface print as-value where name="the name"]] > 0) do={} else={}
Stop.
Too often in scripts you get strange results when using an array and comparing it to simple strings:
:put ({} = "")
true
:put ([:toarray ""] = "")
true
Test for 3rd method:
:put ([:toarray ""] = true)
false
:put ({} = true)
false
:put ([:toarray "1,2,3,4"] = true)
false
:put ({1,2,3,4} = true)
false
