Is this the best way to set-up CAPsMAN to put access points on specific channels? I’ve defined the 5 main channels as individual configurations - I’ve skipped 5180 as most surrounding access points are on that channel:
And then used a regular expression on identity to assign the access points in provisioning:
I’d use “(AP001|AP002).*” as the expression if I wanted to put more than one AP on the same channel. NOTE: regular expressions are case sensitive.
