Hello
What is the best way to upgrade the bios in a routerboard?
I can see where to download the bios but not how to upgrade it.
The manual says you can download some remote ethernet loader thing but I can’t find that.
Hello
http://www.mikrotik.com/testdocs/ros/2.9/system/routerboard.php
Do a /system routerboard upgrade. You might need to manually reboot. The upgrade command should reboot for you (per docs) but doesn’t for me.
I think the eth utility is just for 200 series.
Thanks, sorry about that, I didnt think to look in that part of the manual
Thanks again
Docs are tricky - between the Wiki, routerboard.com and mikrotik.com.
Little pieces here and there…
