I am struggling with finding the best way to setup OSPF on a wireless network. I have two issues. First I don’t really want to advertise all static routes. The reason is that everytime a client connects to a high site or disconnect OSPF will have to update other high sites if that route is available or not.
/routing ospf instance
set default comment="" disabled=no distribute-default=never in-filter=ospf-in \
metric-bgp=auto metric-connected=20 metric-default=1 metric-other-ospf=\
auto metric-rip=20 metric-static=20 name=default out-filter=ospf-out \
redistribute-bgp=no redistribute-connected=no redistribute-other-ospf=no \
redistribute-rip=no redistribute-static=as-type-1 router-id=172.30.5.254
/routing ospf area
set backbone area-id=0.0.0.0 comment="" disabled=no instance=default name=\
backbone type=default
/routing ospf area range
add advertise=yes area=backbone comment="" cost=calculated disabled=no range=\
172.30.5.0/24
172.30.31.20/30
/routing ospf interface
add authentication=none authentication-key="" authentication-key-id=1 \
comment="" cost=10 dead-interval=40s disabled=no hello-interval=10s \
instance-id=0 interface=wlan1 network-type=broadcast passive=no priority=\
1 retransmit-interval=5s transmit-delay=1s use-bfd=no
instance-id=0 interface=ether1 network-type=broadcast passive=yes \
priority=1 retransmit-interval=5s transmit-delay=1s use-bfd=no
instance-id=0 interface=loopback network-type=broadcast passive=yes \
/routing ospf network
add area=backbone comment="" disabled=no network=0.0.0.0/0
/ip route> print where !ospf
Flags: X - disabled, A - active, D - dynamic, C - connect, S - static, r - rip, b - bgp, o - ospf, m - mme,
# DST-ADDRESS PREF-SRC GATEWAY DISTANCE
23 A S ;;; Swaelfontein
172.30.5.32/28 172.30.5.172 1
24 ADC 172.30.5.160/28 172.30.5.174 ether1 0
25 ADC 172.30.5.254/32 172.30.5.254 loopback 0
32 ADC 172.30.31.20/30 172.30.31.22 wlan1 0
Is there a way that I can tell OSPF to advertise the sites assigned subnet of 172.30.5.0/24 which will be advertised regardless a client with a range of 172.30.5.32/28 is connected or not?
At the moment that neighbour router has the following routes.
/ip route> print where !disabled
0 ADo 0.0.0.0/0 172.30.31.5 110
2 ADo 10.0.5.0/24 172.30.31.5 110
3 ADo 172.30.0.0/24 172.30.31.5 110
4 ADo 172.30.0.254/32 172.30.31.5 110
5 ADo 172.30.1.0/24 172.30.31.5 110
6 ADo 172.30.1.252/30 172.30.31.5 110
7 ADo 172.30.1.254/32 172.30.31.5 110
8 A SB 172.30.2.0/24 10
9 A S 172.30.2.0/28 172.30.2.249 1
10 S 172.30.2.16/28 172.30.2.30 1
11 ADC 172.30.2.30/32 172.30.2.254 wlan2-Dennegeur 0
12 A S 172.30.2.48/28 172.30.2.251 1
13 ADC 172.30.2.80/28 172.30.2.94 ether1 0
15 ADC 172.30.2.240/28 172.30.2.254 ether1 0
16 ADC 172.30.2.254/32 172.30.2.254 loopback 0
17 A S 172.30.3.0/24 172.30.31.10 1
18 ADo 172.30.3.0/28 172.30.31.10 110
19 ADo 172.30.3.14/32 172.30.31.10 110
20 ADo 172.30.3.254/32 172.30.31.10 110
21 A S 172.30.4.0/24 172.30.31.10 1
22 ADo 172.30.4.0/28 172.30.31.10 110
23 ADo 172.30.4.14/32 172.30.31.10 110
24 ADo 172.30.4.32/28 172.30.31.10 110
25 ADo 172.30.4.248/30 172.30.31.10 110
26 ADo 172.30.4.254/32 172.30.31.10 110
27 ADo 172.30.5.32/28 172.30.31.22 110
28 ADo 172.30.5.160/28 172.30.31.22 110
29 ADo 172.30.5.254/32 172.30.31.22 110
30 A S 172.30.16.0/24 172.30.2.249 1
31 ADo 172.30.31.0/30 172.30.31.5 110
32 ADC 172.30.31.4/30 172.30.31.6 vlan2 0
33 ADC 172.30.31.8/30 172.30.31.9 wlan1-Zeekoegat 0
34 A S 172.30.31.12/30 172.30.31.10 1
35 Do 172.30.31.12/30 172.30.31.10 110
36 A S 172.30.31.16/30 172.30.2.249 1
37 ADC 172.30.31.20/30 172.30.31.21 wlan3-FMToring 0
38 ADo 172.30.31.32/28 172.30.31.10 110
I have some other routes as well which does not fall in the the networks 172.30.0.0/19 range. I do not want to advertise those routes, but when I enable redistribute static routes it will also advertise the 10.0.5.0/24 route.
What would be the better way to set this up?
