Best wireless connection of 3 rooms in apartment
We bought a new apartment in a new building in Prague (Czech Republic). I work as a programmer, so I need a low latency (vpn, samba, ssh, remote desktop, etc.) as well as high speed transmission (home server that handle copying over 100 MB/s).
Unfortunately, the apartment doesn’t have data wiring and socket of internet is only in the living room. We have a very fast optical internet with ping 1ms to domestic data centers.
It is not possible to run cables around the house, so i search a way to wirelessly connect 3 rooms, and achieve performance approaching to GLAN. Each room should have some proper Mikrotik device, apparently in bridge mode (another device will be connected to the Mikrotik GLAN).
Now i have in the living room RB493G with 1xR52Hn (2x8dBi MMCX antenna) and RB751G-2HnD in bedroom (with internal antenna - i tried also external antenna with 8dBi without any performance proof). I set both devices to use “Nstreme” and point-to-point setup. On both devices is last RouterOS 5.20. The distance is approximately 10 meters and 3 walls (15cm wide) between them.
The result: latency is very good - stable 1ms ping and TCP (Mikrotik bandwidth test) approx. 40Mbps receive and 30 Mbps send. Unfortunately, bandwith is quite slow. I tried also NV2, but it had a high and unstable latency (10-100 ms).
In addition, I want to connect a home server that will be in the chamber (it has 6 noisy HDDs)
Regardless of price, what Mikrotik hardware and what settings would you recommend me to the best connection for 3 rooms wirelessly?
Thank you!
Below are screenshot from my RB751G-2HnD:
Nobody help me? :slight_smile:
I’m looking for max-best wireless connection for 3 rooms…
Have you considered Powerline Ethernet Adapters? Some of them can reach performance of 500Mbps.
There you go. Powerline Ethernet Adapters are best as you have been previously told. It will work for your 3 room apartment .
Powerline Ethernet Adapters are best,so you can try it .you can check something about it from google.
