Best wireless setting at high noise regions
Hi everybody
can you help me to set my link parameter at a region which has a very high noise
i m using 2 RB912 for my link
Show us spectral history
it is not avialable
int wi spectral-history wlan1
failure: allowed ranges [4910; 6110]
The Syntax is:
Spectral-history range=xxxx-xxxx
Fill in the channels which are allowed to you
Enter
0
Enter
