Beta 3 User Manager
I just installed the UserManager package 3.0b5 on an i386 box..
I created the customer.
I brouse to the main screen and enter login.
I hit “login” and i get:
501/503 version not supported.
IE ver 7.0 5730.11
OOPS…
Craig
Things that make you go Hmmmmmm…
FireFox 2.0 under XP shows a main screen but No buttons on left menu..
OOPS !!!
Craig
this is a bug, we have fixed but you must wait for a new package. we will see if we can update the current one.
UPDATE: the package is on the web. the name is the same, so just re-download it.
Cool !!
Im off to see the wizzard…
Craig
Ok…
I loaded the updated file.. :slight_smile:
I now see buttons on the left pane.. :smiley:
Now, try to remove a user… (Yes I checked the check box..)
It just says to select atleast one user… :open_mouth:
OOPS…
Please try again… :frowning:
Craig
“Things That make you go Hmmmmmmm…”
Craig,
Are selected users present at active section ?
You can execute actions with items, that are listed in the active section.
