BETA-4 Question
Dear Normunds,
No new CSMA/CA related feature listed in Changelog..
Do CSMA/CA disabled feature unchanged from beta-3 ?
If we’re not mistaken, in previous post you say,
you would implement new option in this beta (beta-4) ?
Are that cancelled ?
PS :
How about restart bug ? Its also doesn’t mentioned ?
High Regards,
Andrei
:slight_smile: just try it out!
BTW I found “Settings” button in /interface bridge - nice!
maybe I’m missing something here, but could someone elaborate a little on what you are using the IP Firewall for in bridge mode?
this option will make all the traffic bypass the firewall system, and go straight through - this will increase the speed of the bridge by almost 50%. in 2.9 this was not so.
