Beta 9 and SIP NAT Helper
With Beta 9, if the SIP helper (/ip service) is enabled and SIP traffic crosses the router, it will kernel panic and reboot. The only solution I could find right now was to disable the SIP helper.
I am seeing the same issue here.. With a fresh install and running a simple nat rule and the SIP helper enabled… any sip traffic accross the nat rule causes a kernel panic and reboot… Does support need a supout.rif file?
Fred
I’m sure they would like one as well as steps to reproduce it.
send supout.rif to support, if any additional information will be required support will contact you.
done and sent.
I have the same problem. Two ISP DMZ to asteisk .If I neable sip help , the router reboot , If not enable the sip help , sip register but problem with rtp nat-t
Anybody have a solution?
Chris
report to support@mikrotik and wait for beta10.
