I cannot install packages, which i am not using.
I guess it is bug, but for me not critical if going to be fixed in beta11. Configuration must be exported IMHO in any case, and it is wrong if i install routing package, i will need install also ipv6 package.
I am not using ripng!!!.
Just i did system, using regular RIP, and trying to do over such way backup with diff’s.
in beta10 it is crashing on that stage, thats it…
If there is in menu /ripng, i dont have any glue how to remove it separately without removing whole routing package.
