Who anyone know which one has the more powerful CPU?
http://routerboard.com/RB450G
http://routerboard.com/RB2011L-IN
Look at the Ethernet throughput tests listed at the bottom of the page.
They are very close. I’m unsure if they are 100% comparable since tests was not made on same ROS level and RB450G had 2 port test while RB2011 was performed 2-7 ports test… Who knows which one represents the real life performance better.
You all probably remember that a recent version of ROS gave us significant performance boost. RB2011 was released after that ROS, while RB450G was tested before that Router OS version.
I would like to see MD5/AES-128 IPsec throughput for both of them. That would tell me more about CPU itself.
Scroll down on those links - you can use Performance chart to compare boards. 64 byte frames shows pure CPU power.
