no worries, i found a website that sells protective pendants , and i will protect myself. (just joking)
you said that you are a real fan of these devices, my question is: how will you do it? design, speed, 2.4 (&5), price, safety
Thanks,
Thanks,
you forgot the most important factor ..your budget
as said before, I would go for cAP
I already wrote it here. Wires everywhere is the rule nr. 1. (ended in the switch, e.g. some version of CRS125). Then RB951G-2HnD for the rest with accordingly reduced transmitt power. Maybe you would need one per 2-3 rooms.
If you have a lot of money, I would go by ac (RB922UAGS-5HPacD with additional 2HnD card and antennas in the ceiling enclosure). As it has fibre, I would use the fibre for uplink to the switch. Unfortunatelly Mikrotik does not offer any full optical switch with many ports, so you would need to buy some other brand (just for inspiration, something like this: http://www.celan.com.tw/products1/Switch%20G2416i-EV.html or similar with the as many ports as you need).
Of course you can run without fiber, using gigabit ethernet everywhere.
Great thread,
I face a similar situation, renovating apartment, need good & reliable wifi coverage.
I was thinking about having just one 2.4ghz AP and many 5ghz ac ap, one for each important room.
and RB922UAGS-5HPacD + 2ghz card and required antennas for the living, and i think best case scenario this will do it for the whole apartment.
If the other rooms have poor wifi reception i need to add another ap, most likely 5ghz ac.
Which model whould that be? an 2ghz with a 5ghz ac card?
and one more thing. is it possible to skip the enclosure (the stationbox) and leave the board+antennas hidden in the ceiling (with no case)?
if there is no moisture or lots of dust, there should be no problems. I have actually seen working routerboards with a thick layer of dust on them, but I can’t suggest that
depends on the environment, in a typical apartment, there shouldn’t be anything dangerous in that space
good to know.
i was actually afraid of RF interference on pigtails of the board.
i thought the metal case shileded the unit from, at least some, rf noise.
Case is just for protection of the board and peripherals. If you think it cannot be damaged where you put it, there is no other reason to use the case. Think where and how to mount the device to be able to access it physically if you need.
Any recommendation on what cable to use for some sort of future proof?
cat6/cat7 ?
up to which frequency 500-1200mhz?
UPDATE: seems that cat6 sftp or any cat7 would do for now even though i will bent it at 90 degrees and use cat6 wall sockets.
the last piece of the puzzle, or wish, is a cheap 5ghz AC mikrotik device with l4 license to use where the signal is not ok.
Use the best cable you can afford…
Should i worry about shielded cable (sftp)?
the cat cables will be next (parallel) to 220v cables.
It is not recommended to lie data cables along the AC power cables. But if it is shielded well, it will not make any problems. You will not have it hundreds of meters along, just few, so do not worry…
