Better understanding IPsec modes
Can you please explain with configuration on the differences between transport mode and tunnel mode.
i know that in tunnel mode both the ip and payload are encrypted
why not always use tunnel mode?
why use transport mode?
I noticed in ipsec policy if i put the same ip addresses let’s say for a l2tp interface for src-address; dst-address to sa src-address and sa dst-address … both tunnel and transport mode would work.
what is the difference? it is not clear.
what is the template checkbox for?, I noticed that in transport mode if src-address and dst-address are subnets an error pops up but if i check template the error goes away.
can you please clarify on the whole subject.
bump!
http://www.firewall.cx/networking-topics/protocols/870-ipsec-modes.html
Here you have nice explanation and some examples of ipsec modes.
Yes, it is a good article :slight_smile:
but can someone please explain why this happens.
Did you really get an L2TP connection to work over an IPSec tunnel in tunnel mode? That never worked for me. So I would say the basic differences are:
Tunnel mode:
Can be used if no interface is required. The subnet that can be reached through the tunnel is entered in the field dst-address (xxx.xxx.xxx.xxx/xx) while src-address is your subnet. Routing to the destination subnet should work as soon as the tunnel is up.
Transport mode:
I used transport mode to be able to establish an L2TP connection on top of it. This gives me an interface I can use for policy based routing. When setting up a tunnel in transport mode dst-address cannot be a subnet and therefore additional manual routing entries become necessary in order to be able to reach that subnet.
For the use of the template checkbox please refer to http://wiki.mikrotik.com/wiki/Manual:IP/IPsec
I never used policy groups, so I cannot provide further details or share experience.
Hope that helps.
Kind regards,
iBlueDragon
yes i got it to work after i checked the template checkbox, which I don’t understand and that what confused me.
I put /32 addresses in both sa-src and dst and src and dst and i checked tunnel mode and template and it worked.
can someone please explain why.
